delete flowmon group
delete flowmon group group_name
Description
Deletes a Flow Monitor group.
Syntax Description
group Specifies the Flow Monitor group.
group_name Specifies the assigned name of the Flow Monitor group. Range is 32 characters.
Default
N/A.
Usage Guidelines
An enabled group can't be deleted and the system will reject any attempt to do so. Groups must be disabled before deleting.
The system will also reject any attempt to delete a group that does not already exist.
The following command deletes a group with the name 'max-flow-age':
# delete flowmon group max-flow-age
This command was first available in ExtremeXOS 32.2.
Platform Availability
This command is available on ExtremeSwitching 5520, 5420, and 5720 series switches.
